跳转到主内容
修复你的物品
维修的权力
商店
型号A1367,闪存容量:8、16、32及64GB
1313 个问题 查看全部
Won't Register Home and Power Buttons Being Clicked
Whenever I click either the home button or the power button, nothing happens. In order to get the iPod to come on I have to plug it in, but then once I'm on I am stuck on one thing and I can't get out of it. Can I replace just some parts and if so which ones, or would I be better off just to get a new iPod. It got wet once, so that might be part of the problem....
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
When you say that it got wet once, what happened? Did you clean it after?
完成的
No, I didn't clean it. It was in a bag with a water bottle that leaked. I just left it because I had a case on it so I don't think too much water got in, and it started acting up after that, but it's been getting better ever since until now.
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
已选择的解决方案
Michaela, it is possible that you are having corrosion damage to the dock connector as well as battery issues related to the water damage. I suggest that you clean your iPod. I would use the same principal as outlined in in this guide. Use the guides from here to get to the inside part of the iPod. Once cleaned, replace the battery for sure. Re-evaluate for any further damage. Once you have it cleaned, installed a new battery, try to restore your iPod. Hope this helps to get you started.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michaela 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 590
