Back glass dimensions, or schematic
Hey, I'm trying to 3d print or CNC a replacement back glass panel for my phone, but I can't find any dimensions anywhere
Does anyone have measurements, or should I order a replacement and take them myself
Here's a link showing the phone's overall specifications including the dimensions that may help.
Here's the ifixit Samsung Galaxy S24+ repair guide that may come in handy when you have printed the back glass panel.
这个答案有帮助吗?
I found this CAD:
https://www.printables.com/model/748111-...
I recently did a similar thing for iPhones, I got a bamboo iPhone X back and an acryl iPhone 12 mini :-). Laser cutting is probably your best bet as CNC is quite expensive and 3D printing is either fragile (layered) or will lose its accuracy because of hardening (resin).
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 302
Hey, thanks for replying! Unfortunately, I need exact measurements. I was just asking here before I order one to measure myself.
由 Stuart Greer 完成的
@stuartgree53900
I thought that down to a 1/10th of a mm (0.1mm) would be accurate enough.
Even Vernier callipers only go down to 0.1mm.
How do you intend to measure it more accurately? Just curious
由 jayeff 完成的
Doing it myself will probably be fine I just wanted to see if anyone else had done it.
由 Stuart Greer 完成的
