usb broken, do not recognize anything that is connected.
as I can fix usb ports do not recognize any device?
ramvideos@yahoo.com
thank you.
A common issue with the T42 affecting either the display or USB ports is flexing of the motherboard which can take out either component. See the following link:
http://forum.thinkpads.com/viewtopic.php...
I'm having an intermittent display problem due to this. It may be possible the only solution is re-balling the MB or replacing it. The above link gives all the details. Good Luck!!!
这个答案有帮助吗?
thank you...
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,257
4条评论
Do your USB ports show up in your system bios? Do they show up in the device manager under windows?
由 oldturkey03 完成的
if they appear in the system bios.
由 ramon vale 完成的
What does show in the device manager? What operating system do you have? Windows/Linux?
由 oldturkey03 完成的
windows xp sp 3
由 ramon vale 完成的
