跳转到主内容
Steam Deck OLED 的维修、拆卸和故障排除信息, Steam Deck OLED 是 Valve 制造的掌上游戏机的 2023 年新版。于 2023 年 11 月 16 日发布。型号标识为 1030。
There's a 1/4" White Line across the bottom of Newly-Replaced Screen
I recently replaced a cracked screen in my steam deck OLED (512 GB) and a white bar appears across the new screen when I boot it up. Everything else looks alright, if not a bit low-resolution. The white strip blocks out UI and gameplay that expect that part of the screen to be working. It does scale in brightness along with the rest of the display, and occasionally red and yellow horizontal strips appear inside that white strip
I have uninstalled, then reinstalled this screen three times trying to see if it was the connector and making sure the pins matched the instructional photo. This is the result each time. I would put my old screen back in to test, but it has been shattered and will not display anything. I am wondering if this may be a compatibility issue or if perhaps I received a defective screen replacement. Here some images of the display model#s in case that helps.
Old Display:
New Display:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
did you get this resolved? i am having the same issue.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi there!
It does sound like a bad replacement part.
1 way to test, is to test it with another screen.
I would return the part and get yourself a new one! See if that fixed it. If the exact same issues comes up again, then you do know that it's something else. 1 way to make it easy, test with another screen!
If you have any questions, please let us know!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Austin Van Haitsma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 48
总计 208
