跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Nespresso Inissia coffee machines.
Where can I find this part replacement
Where can I find this part:
it looks like some sensor
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi Gregorio,
Can you post more pictures of this thing from different angles? I admit you've got me stumped as to what it might be; all I can make out is what appears to be a power transistor that looks pretty fried to me. Perhaps more views might help us make out what it's supposed to be. It would also help if you could add the model number of your Nespresso.
What happened to get it in this state?
完成的
添加一条评论
1个答案
已选择的解决方案
After digging into this a bit more, it appears that component is part of an assembly called the thermoblock. I assume it has to do with heating the water, thus giving the power transistor a reason for being. I don't see any indications that the thermoblock is sold in anything less than a complete assembly; in other words it doesn't look like you can buy just the part you've shown in your photo; rather you have to buy the whole assembly.
I didn't do an extensive search for the part, but here's one page I found showing a picture of it; the part on the right side looks like what you are seeking.
Thermoblock 230v Nespresso FL300204
That's the part number, FL300204, if you want to search it out yourself. It states this is a 230V part, so obviously it's not for use here in the United States; please verify the voltage is correct for your particular model.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gregorio Rosa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 29
总计 298
