跳转到主内容
M1 Mac mini 是Apple的首部使用自研單晶片系統(SoC)的機型之一,整合了中央處理器(CPU)、圖形處理器(GPU)、記憶體(RAM)等等主要元件,以提升能耗比。此代Mac mini 的M1芯片CPU擁有8個核心,其中有4顆是效能核心(P-Core),而另外4顆為效率核心(E-Core),並帶有8核心的GPU。
AC2 "Unexpected device state 'DFU' expected 'RestoreOS'" Error 4014
My mac mini has sadly been rendered unbootable after a power surge. It will chime and immediately turns to an SOS blinking amber light.
As a disclaimer, I know this may be a hardware issue and that is why I am here. I have already taken it to Apple and they had no luck, telling me it needs a logic board replacement. It wasn't worth the money so this has turned into just a slow learning project that I've been chipping away at as a hobby.
I have tried to restore it with Apple Configurator and another MacBook, but after putting it into DFU mode and waiting for it to restore, it fails with this error (4014)
AC recognizes the Mac Mini, and the restore works up until Step 4/4, "Installing System", where it pauses halfway and then gives that error.
At that point I can see via the status light on the Mac Mini that it goes from a normal boot (white) to DFU mode again (solid amber) randomly, and AC sort of flickers at this point as well and then complains about the Mac Mini being in DFU (instead of RestoreOS).
I guess this could be something fried on the board, but I wouldn't know where to start because the only apparent issue being that it just randomly dips out of RestoreOS and back to DFU is very odd.
I've heard this error (4014) can be a faulty cable, but I've tried a lot of different ones, including a genuine Apple USB-C cable. I may buy a brand new one and try again.
Do you know of any software or hardware issues this could be? It seems like a simple issue but with no real rhyme or reason to it. Even if you just have a hunch, any tips on where I should look next would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I can’t say for sure but it does sound like the Flash chips got corrupted so the low level and OS is not recognized. As you are able to enter into DFU the system is mostly working (SoC).
这个答案有帮助吗?
得分 1
添加一条评论
I was having the same issue and dove into looking for a hardware issue. I found this chip under the heatsink with a hole in it. I tried to search for what this chip does with no luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kanen Stephens 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 43
过去 30 天: 170
总计 1,781
