跳转到主内容
加入维修社区 - 创建账户
Flashing white bar LG 65UH6030
Hello all,
I have a LG 65UH6030 and when I plug it in and turn it on there is a bar about 6 inches wide that flashes on and off, part of the flashing bar is white. No picture other than the flashing. Could this be the Power board causing this? I appreciate the help.
Update (01/02/25)
Didn't think about the position of it, vertical.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @gscott46993
You didn't specify whether the flashing line was a vertical or horizontal line.
Here's the service manual that may help.
Go to p.66 thru p.70 (of 78 pdf) to view the images of problems seen on the screen and check if you can find one that is close to what the problem is in your TV. The image seen on the display indicates where the problem is.
It seems more like a screen problem (known as module in the manual) more than a power board problem, although it could be a mainboard problem also.
这个答案有帮助吗?
得分 1
1条评论:
This the one that looks the closest, Vertical Block
Source TAB IC Defect. I will check it again when I get home.
Thanks,
由完成的
添加一条评论
@gscott46993 let's see what this looks like. Post some pictures of what your screen shows with your question. That way we can see what you see.
From what you are describing. this indeed sounds like a Source Driver situation, but it is most likely brought on by a failed COF (that is the plastic film connector between the driver boards and the LCD) because of the width of it (you described it as ~ 6inch).
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
2条评论:
I will get pictures uploaded this weekend. Is this issue repairable if this is what the problem is?
由完成的
@gscott46993 maybe not fixed but corrected for some time :-)
由完成的
添加一条评论
添加你的答案
Gscott 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 366
