跳转到主内容
How to connect keyboard cable in MBP?
MacBook Pro 15" Santa Rosa
Well, I had a little problem with my keyboard a few weeks ago (could not type 'A') so I opened my laptop up according to MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement and cleaned the keyboard up (hoping it would solve that problem)... But then I could not figure how to "slide the keyboard ribbon back into the connector" so I'm left with a laptop without a working keyboard... I've tried stuffing it back in but it would only go in about 1mm, not enough to make the connection... any way to connect it back in?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
It's a cam - it lifts up (very gently from the insertion end) you insert the ribbon cable then push the cam back down.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
3条评论:
how do i lift it up?
完成的
Get a magnifying glass, examine the connector. Lift up the black plastic flap holding the ribbon in place (vertical ) slide in the ribbon, press down the flap.
完成的
oh.. so it is opened from the back? haha ok i'll try again...
完成的
添加一条评论
最有帮助的答案
See step #11 of the guide you used.
这个答案有帮助吗?
得分 3
1条评论:
the problem is that the guide does not show the outcome of flipping the flap up... anyone can post a photo of it? haha...
完成的
添加一条评论
Use tweezers, they help in get a little more of cable and then push it into the slot deeper)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
xkiller213 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,366
