跳转到主内容
MacBook Pro a1989 how to fix ripped capacitor
How I can recover my motherboard thx for help anyway
Update (12/29/24)
I cant even put wick on it 😔
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like the iron is not hot enough. You may need a new tip and make sure the tip is fully wetted with solder. When working some boards the copper traces sap away the heat. I often find I need a hot air rework station as well as a fair amount of foil to protect the other stuff from too much heat.
I’ll need to dig out my schematics and board view drawings to ID the SMD you’ve identified. I’ll catch you tomorrow with an update. In the meantime get some isopropyl alcohol to clean up the board a bit.
这个答案有帮助吗?
得分 1
1条评论:
Oh ok that's putted a new light Excellent thank you so much!
完成的
添加一条评论
添加你的答案
Damian Kaminski 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 119
