Why is my phone can't read sdcard?
So one day a random notification happen after restart, it said need to format my sd card so i moved my file to my drive, then i insert the sd card back its not detecting not even a notification or something, i tried to update the MI UI it doesn't affect it, I've tried restarting, cleaning the sd card using an eraser, formating the sd card in my laptop, and it still can't read it, although my laptop can read the sd card just fine
in the about phone > storage
it doesnt have the sd card part, only the internal storage, this is what i usually go when sd card is detected or not.
Have you tried other SD cards? Could be the card is just done. I had similar issue with a dashcam. Card would not work in the dashcam but worked in everything else I plugged it into.
由 Cat Juggler 完成的
