跳转到主内容
加入维修社区 - 创建账户
There power going to computer but it won't turn on
Won't come on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @kellycannady
What is the full model number of the AIO as shown on the product information label on the back?
完成的
@jayeff No.J4W49AA#ABA
完成的
添加一条评论
2个答案
@curtisfields
From the product ID number you posted, I think that it's an HP All-in-One 19-3013w E1, Daisy Kabini Aio AMPKB-PT Rev1.02 motherboard
Assuming that you've proved that there's 19.5V DC on the output plug of the adapter, you may have to open it up and check for power from the DC-In jack (example only) onto the board and then further into the motherboard. Not easy without the schematics. I can't find any motherboard schematics for it. You may have better luck.
It may be that the jack is faulty.
这个答案有帮助吗?
得分 0
添加一条评论
1.CHECK if power light/fan turns on. If yes then power is reaching the system.
  1. DO A FULL POWER DRAIN, unplug the power adapter, Hold the power button for 30 seconds, Plug the power back in and try to boot.
这个答案有帮助吗?
得分 0
2条评论:
Ok that is the only way I. An get my computer to turn on .. so what is causing it and it may take several time to get it to turn on .
完成的
How do I fix it to turn on every time ?
It's barley ever used . Help
完成的
添加一条评论
添加你的答案
Kelly Cannady 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 30
总计 380
