跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3660 个问题 查看全部
问题已关闭
No LED Light on Magsafe Adapter
I have a first generation MacBook (Core Duo) that was given to me by a friend. The MB works great except that the magsafe charger doesn't charge the battery. The MB recognizes the adapter but just says "Not Charging." I have a new battery and have tried my daughter's adapter and they work fine.
The LED light on my magsafe also doesn't light up at all. I thought the adapter might be faulty, but it seems to work on my daughter's MB. It also runs my MB when plugged into the wall; just does not charge the battery.
Could this be a problem with the MB's magsafe connector (the part inside the MB that connects to the logic board)? I'm just hoping it is not the logic board.
Thanks for any help you might be able to offer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
just checking - is your daughter's Magsafe adapter a 60W version? or does she have a MacBook Air and it's corresponding 45W charger?
your MacBook needs the 60W (or higher) to charge the battery. if by chance you're trying to use the MacBook Air's 45W charger, it might run the MacBook but not have enough power to charge the battery.
if you're not using a MacBook Air charger, then ignore the above - it would be some other problem.
这个答案有帮助吗?
得分 0
评论:
Thanks for the comment.
No, both MBs are the 13" Core Duo models. They are basically equivalent with 1.83 GHz processors.
完成的
Can you see the SAITE numbers on the adapters?
完成的
Sorry, what exactly are the SAITE numbers? Are those the output wattage, etc. of the adapter?
完成的
At the end of the top line on the adapter. Also is there a Apple logo on the outside of the adapter?
完成的
This is not an Apple adapter. It is an off-brand replacement. The numbers are: Model No. 1184; INPUT: 100 - 240V - 1.5A; 50 - 60Hz; OUTPUT: 16.5V - 3.65A.
完成的
显示更多的1条评论
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 7,062
