跳转到主内容
The sixth generation of the Mazda Protegé, also known as the Mazda Familia and the Mazda 323. The five-door fastback edition was known as the Familia Astina or the 323F.
12 个问题 查看全部
Why is my cooling fan not kicking on?
cant find cooling fan relay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
最有帮助的答案
jeff, it is in the power box inside the engine compartment. Cooling fan relay is number 8. You also want to check the radiator cooling fan thermoswitch. That is the one on the thermostat housing and it controls the fan. Your Mazda has actually three sensors. One for the cooling fan, one to send a signal to the gauge, and one to send the signal to the ecu. number 2 in the second image is the engine coolant temp sensor. from here Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
i have mitubish outlander my cooling fan dont kick without turning on the aircoudition
这个答案有帮助吗?
得分 0
2条评论:
alberto, what year is your Outlander? What engine and what type of transmission? You say "without turning on the aircondition" so it works when you turn on the AC?
完成的
My 1989 Mazda protege fans were working fine but I washed my engine and now they are not working what did I do to hurt the fans
完成的
添加一条评论
I have this issue too. 97 familia, 1.5L manual.
Driving home the other day...bumped the kerb lightly as I parked up then temp light came on. Have tested relays, fuses, coolant temp sensor, thermostat ( all working as normal)....fans won't kick on at all.
This is really starting to do my head in.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 12,461
