跳转到主内容
加入维修社区 - 创建账户
2013 MacBook Pro 13" A1425 - POWER ISSUE
Model: MacBook Pro (Retina, 13-inch, Early 2013) - A1425
MacOS: Catalina 10.15.7
Processor: 2.6GHz Dual-Core i5
Memory/Storage: 8GB/256GB
Battery Info: (See attached pictures) Cycle Count: 1, Condition: Normal
Problem TLDR: MacBook is not working unless charger is plugged in - battery appears to be in perfect condition.
Backstory: The original battery was starting to balloon, so the previous owner (who is tech-savvy) bought a new battery from Amazon. The replacement battery was tested (before using the adhesive) and the laptop would turn off the moment it was unplugged. It also wouldn't turn on unless plugged in. The owner then bought ANOTHER third party battery, and this issue persisted. The owner also informed me that he tried the original battery again and still same result.
What I've done so far: When I bought this laptop to fix, the battery icon in the top right said "79% Battery Not Charging" (MagSafe 2 Light Amber). Previous owner said it wasn't going up no matter how long he left it plugged in.
- When I took it home, first things I tried were SMC and PRAM reset - no change.
- Then I decided to take out the battery and inspect the battery/logic boards - no visible water damage.
- The DC-in board was a little wonky with the MagSafe 2 charger so I decided to unscrew it, and re-seat it. I noticed that it might have had a bit of something sticky on it at some point. I cleaned the one side with IPA - couldn't check the other side as this would require I take out the logic board and I haven't done that yet. The pins on both the 3rd party 60W charger, and the DC-in board look perfect.
- I put the battery back in, turned it on - there was a change! Now, as per attached picture, the Battery is at 100% and says "Battery Is Charged" (MagSafe 2 Light now GREEN). But the laptop still turns off when I unplug it.
What's Next?: I know the easy answer is to get another battery, but I think there is enough evidence here to first explore other alternatives. The odds of two third party batteries in a row being duds isn't 0%, but it seems unlikely. I'd like to exhaust my options, opting for possibly buying the $20 DC-in Board before $130 on an iFixit battery. My thoughts are that the battery is in good health based on the laptop recognizing it, and the fact that it's new, but the MacBook is not properly switching between Power Adapter and Battery. Is this a known possibility? Is this something that the DC-in board controls?
I plan on removing the logic board for complete inspection in the next day or two and I can update on anything I find (or don't find). Please let me know any information or relevant experience you have with this situation. Any information on how the DC-in board works, what controls the switch from charger to battery, what parts on the logic board to inspect... ANYTHING. I'm just getting into laptop repair in the past month and I'm really excited to learn.
EDIT 1: In response to Dan requesting Coconut Battery Photos
Had to get an older version of Coconut Battery(3.6.6) because I'm only running Catalina, hopefully no differences in info though.
EDIT 2: Testing done 2024-12-10 with the MagSafe 2 Charger plugged in.
  1. The first thing I tested was the Fuse F7040 which protects PPBUS_G3H. I got around 12.3-12.6V on each side of this fuse which confirms PPBUS_G3H is present and the fuse is good.
  2. R7050 coming from battery: 12.3-12.6V on each side. This I believe confirms the battery is providing voltage correct?
  3. From here I didn't know what to do next but I tested MOSFET Q7800... this looked like it had 6 pins (3 on left 3 on right) but the .brd has the component in a different orientation with 7 pins. Either way I got 3.3V on what I believe to be the Gate and Drain sides, and then 0V on both of the Sources? The 0V was on top right and bottom left pin if your orientation is with the battery closest to you. If true this would mean that the MOFSET isn't switching properly?
  4. I wanted to test if the SMC control signals. I took the board out and I went to U5010 which is labelled SMC PWRGD. This component has 9 pins, I tested 2 so far. Pin 1 which is PP3V42_G3H has 3.3V and Pin 5 which is SMC_RESET_R_L also gives 3.3V.
This is where I ended as I was just getting more confused about what I'm supposed to be looking for and was hoping I could get a little more direction. I will also note that on Step 4 after I took the board out (no SSD or battery) and plugged it into again, the fans would run absolutely wild for a bit before stopping. The heat sink wasn't at all warm but the fans would go crazy - is this normal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I heard from louis rossmann about the lcd macbook pro having battery issues because of incorrect installation and killing the smc
完成的
@senopatib
Hey thanks for the response! I'll try looking for this video but he has so many - any chance you have a link?
完成的
添加一条评论
1个答案
Let’s look a bit deeper here into the power logic, install this gem of an App CoconutBattery with the charger plugged it take a snapshot of the Apss main window and post it here so we can see it too.
Update (12/06/24)
So it’s clear SMC is working and correctly. The removal of the battery and leaving it in that state basically did a SMC hard reset which is why the system came back from its confused state. It’s not uncommon to need to do a hard reset. Most of the time after disconnecting the battery and nothing connected to the system, we press and hold the power button to fully discharge the logic board of any remaining power holding the button for a good 15secs.
So where does that leave us? Just like a stair/hall light with a switch at the both ends to either turn on and then when you get to the other side turn the light off we have a similar logic on the logic board which manages this via a set of MOSFET switches.
This will require access to the schematics and board view drawings so you can isolate out which MOSFET and/or its support logic needs replacing as it’s clear either it was damaged during the previous repair attempts or it might have been damaged by the knockoff charger people often got not knowing it wasn’t a real Apple unit.
这个答案有帮助吗?
得分 0
8条评论:
Hey Dan, thanks for the response. I've added the Coconut Battery pics to the post! Noticed it says "Charging with 0 Watts" and I'm assuming that's just because the battery is full and isn't charging?
完成的
Response to Update (12/06/24)
Okay sounds good, I've started looking at the schematics & trying to learn how to begin diagnosing this issue. I'm new to this so any good tutorials would help.
Took logic board out - no clear water or burn damage anywhere just by looking at it.
I did something very stupid just now... with the board out and the battery disconnected, I went to plug in the charger to see if it could power the board for testing. I had my hand on the DC-in board like an idiot and the MagSafe charger that was right beside it snapped into place while my thumb was on it - instantly burnt a little crater into my thumb. I removed the charger and smelt burning... there's burn damage on the DC-in board. NOTE: MagSafe charger wasn't exactly lined up when it snapped in place.
My question is - is this normal? Does this provide any additional info to the possible problem? I'm assuming I definitely need to order another DC-in board?
完成的
@dante98418 - Ouch! That I bet hurt. Creating a short can cause issues upstream. Here you could have shorted out the one-wire comm link between the system SMC and the charger as well as damaged the DC-In board. I would re-lace the DC-In board at this point and this time with the logic board back in and fully connected try things again are we at least back to square one? If not this maybe getting more complex.
完成的
Hey Dan! So the good news is we are still at square one and didn't move backwards! The new DC-in board works and the laptop is still in the same situation. I did some testing and will post it above under EDIT 2. I hope it makes sense, I'm new to this so not entirely sure if what I'm doing is correct.
完成的
@dante98418 - Focus in on the MOSFET logic that’s your issue. You need to ID the gate type is it NPN or PNP as that sets which way the Gate and Drain will react. There is a second set of MOSFET’s you’ll need to check them as well. Don’t over focus on the chip check the support logic as well.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Dante 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 271
