MacBook Pro 13" m1 vertical and horizontal lines
I am getting vertical and horizontal lines on my display MacBook Pro 13" m1
Have you recently opened the case to look inside / replace something / or other reason?
Maybe the LCD cable has either come lose, not connected fully, or developed some fault.
Check that 1st, and if the issue still persists then you have a deeper issue somewhere.....
Here is the guide for 2020年末期带两个Thunderbolt端口13寸MacBook Pro 显示屏总成更换
Disconnect the battery before doing anything!
这个答案有帮助吗?
@livfe - Lines on the screen points to a damaged LCD display. As he is stating both horizontal and vertical the screen has a puncture point within the middle somewhere where the two meetup. If it was only one direction it’s often a damaged T-CON cable to LCD panel.
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 238
1条评论
Can you add a picture to your post? It will help if we can see what you're seeing.
由 Alisha C 完成的
