跳转到主内容
加入维修社区 - 创建账户
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
Water damage- sound and vibration worked. Replaced screen- no life?
3-4 years ago, our tablet had some water damage near charging port. We held onto it because there was still sound/vibration after the damage until the battery ran out. This was before I had experience/knowledge on repairing electronics.
I opened it up and noticed no visible water damage on the charging sub-board, but water indicator sticker on it has signs of wetness. The sticker on the case near the top is ok, as well as the sticker near the sim card tray. I plugged it in with a voltage/amperage meter and the tablet is pulling in power. I tested the battery with a multimeter; it was showing ~3.5V.
I ordered a replacement screen and after connecting said screen, tablet would not turn on. I transferred the small parts from the old screen to the new. No change on the amp meter after the screen installation. I let it charge for ~30 min and tried to power on- no go. I tried to boot into fastboot, power+volume down- no go. Nothing has worked.
There is 0 sign of actual liquid damage. The LCD connector on the board looks good/undamaged, as well as the flex cable connector on the LCD. Any ideas??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rachelcruz
Here's the service manual for the tablet that may help.
Go to p.79 and follow the Display troubleshooting flowchart and check if that shows where the problem is.
There's a board layout on p.69 showing the location of all the components. You may have to zoom in to find the component ID of the components mentioned in the flowchart.
If you find a faulty component search through the parts list (starts on p.35) for the component's ID to find the Samsung part number for the part. Search online for the part number to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rachel Cruz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 191
