跳转到主内容
加入维修社区 - 创建账户
The ninth generation of Chevrolet Impala debuted for the 2006 model year. This generation of Impala was offered as a front wheel drive four door sedan, and was powered by a wide range of V6 engines. Production continued for fleet versions until 2016 under the name "Impala Limited".
My power locks don't always lock and unlock- especially if its HOT out
Where should I start? If the temperatures are over 80 degrees the power locks don't work right, I can hear the mechanism trying to lock or unlock but the button cant move enough to lock or unlock the door.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
@imthebookkeeper what exact year and model is your Impala? Does this mean none of the doors unlock when it is "Hot" (80 deg F is pleasantly warm but not hot).
完成的
It’s a 2008. And it’s kinda random. In the morning while it’s still cool the doors seem to work as it gets hotter then maybe one won’t work- the hotter it gets the worse the locks get. Subjection aside- I said over 80 is where it starts.
完成的
@imthebookkeeper ;-) that does sound like an issue with the actuator. Let me check for a wiring diagram. Does this only happen when you use your key or does it happen with the main switch on the drivers door as well?
完成的
@oldturkey03 my key fob doesn't work for the locks anymore at all- only the trunk. I can open the door with my key without issues, its just using the door lock button on the door that it does this and its the same with the buttons on both doors.
完成的
添加一条评论
2个答案
最有帮助的答案
The general answer is that it could be a bad door actuator or a bad ground connection for that actuator. A bad switch would affect all the door actuators. Usually, door actuators either work or they don't; they're usually not intermittent. So, I would start by cleaning the ground connection to that actuator to eliminate the possibility of a bad ground. Next, I'd check for corrosion inside the electrical connector to the actuator.
这个答案有帮助吗?
得分 2
添加一条评论
Had this same issue 2008 Impala 3.5L. Search youtube for video of replacing door lock actuators cheap. He bought 4 cheap actuators on amazon. With a little work I replaced all 4 of mine in a few hours. They r wired into the factory wiring so they work like factory locks. Zone Tech Car Universal High Power Door Lock Actuator - Premium Quality Heavy Duty Durable Automotive Locking Mechanism (2-Pack) https://a.co/d/cdQqjeQ the video on youtube shows detailed installation. Its not a hard job for most anybody.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
imthebookkeeper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 55
总计 647
