MBP A1226 doesn't boot on SL on a SSD
Like so many people, I installed a SSD in place of the HD, and shifted the HD in a SATA/ PATA caddy, in place of the DVD...
Then I did a clean install of SL 10.6.8, migrated applications and data.
But the MBP is unable to boot on the SSD.
I can have it boot after disabling extensions (shift key) or "manually" when selected after holding the option key at start-up. Not very convenient, hum?!
Any idea? Because of this problem, I tried another brand of SSD (SanDisk; the first one being an OCZ Petrol. both in SATA III). The same problem occurred.
I was told to update to Lion, who is supposed to fix the problem but I don't want to (I need some Rosetta softwares). I can't believe pre-unibody MBP 153 just don't accept SSDs! This would have been displayed on the best Websites and forums like the iFixit ones!
Thanks for your thoughts and solutions!
2条评论
How quickly are you giving up on that boot? Sometimes that first boot from an update can take quite a while.
由 originalmachead 完成的
Thanks Machead3.
I gave up after 15 mn (coffee then sooo many other things to do!).
I did that repeatedly (without coffee), as an attempt to overcome the "random behavior" I noticed: with the OCZ it boots, say, 90% of time when option key is holded and SSD selected. With the SanDisk the percentage comes down to 0% approx...
由 Jean Luc 完成的
