跳转到主内容
加入维修社区 - 创建账户
Jura Impressa F50 全自动咖啡机维修和拆解指南
How to perform decalcification forcefully on Jura F50.
My water flow is very weak and I think it's due to no decalcination cycle in a long time. In instruction it says to wait for message and only then you can do it. There is no maintenance menu for separate de-scaling.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
@vladyslavm48017 here are the DESCALING instructions right from the manual Chapter 18:
and in writing just in case the images are not good enough :-)
Descaling
Again, these are the DESCALING instructions, NOT the cleaning instructions
这个答案有帮助吗?
得分 1
1条评论:
Thank you all for help. My translated manual didn't have a line about screen off.
由完成的 分享
添加一条评论
最有帮助的答案
(0) Important prerequisite: machine is in stand-by, filter status off.
(1) Press the rinse button for four seconds
(2) Now empty the drip tray as requested, it must be outside for at least 5 seconds.
(3) Dissolve the descaling agent (Ammonium sulfatic acid is best) and pour it into the tank. Place a larger container under the steam outlet.
(4) Turn on the steam tap
这个答案有帮助吗?
得分 2
2条评论:
It is normal cleaning instruction, it will not start de-scaling process, that I want to do.
由完成的 分享
No, this is for descaling. Perhaps I should write "maintanance button", nor "rinse button". Anyway, this is the button with six drops on it.
由完成的 分享
添加一条评论
I’ve used CLR Lime & Rust cleaner and making sure to fully rinse out the reservoir and lines. You may need to use a loadable pod to fake out the machine.
这个答案有帮助吗?
得分 0
4条评论:
How do I start decalcination on this coffee machine? There is no button for this or menu button. I can only hope that message that it needs decalcination pop-up. I have cleaning powder for decalcification.
由完成的 分享
由完成的 分享
I need to do de-scaling. Not ordinary cleaning.
由完成的 分享
@vladyslavm48017 - I don’t know this exact system, cleaning is just the term used by this maker as there is really no difference between cleaning and de-scaling (removing lime build up) is just the chemical aspect of cleaning using more effective solutions than water alone.
由完成的 分享
添加一条评论
Cu expresorul oprit, țineți apăsat pe butonul de clătire, până apare mesajul de curățare a tavitei,...in acel moment, incepe propriu zis procedeul de decalcifiere...care are durata de circa 40 minute....
Spor...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vladyslav Mrynskyi 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 64
总计 1,800
