跳转到主内容
加入维修社区 - 创建账户
Sony mhc-gn100d specific buttons not working.
Hello everyone, I am here seeking help on the issue with my home theatre/stereo . There are specific buttons on it which don't work. I disassembled the device and cleaned everything but no luck. Can you please help me? The switches themselves seem to be fine but the click doesn't Actually register. Any hellp will be appreciated. I have attached a few pictures fir reference. ``
this is the main board where all buttons are located. The blue ones won't work.
this is the backside of the board``. I am also attaching service manual where somebody can understand it.Hcdgn100d
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @arnavmalhotra
All the keys highlighted in the image you posted are connected in a matrix arrangement and connect to pins 64-66 of IC901 (see p.36 of the service manual you linked).
Unfortunately there's no circuit diagram of what the other side of the switches connect to.
It must be something common for all of them not to register when pressed.
Check if there's on earth (or voltage) on one side of each switch in the normal position
这个答案有帮助吗?
得分 2
12条评论:
hey. thank you so much for the reply. is there any chance that the ic itself could be bad?
from my understnding, the resistors add resistance and that is how the ic interprets it. since the resistor are highly unlikely to fail, it leads me to believe the ic itself is bad. literally every problem is wth that one rail, with all buttons above tape A/B. i could be wring tho.
ALso, can you help me regarding the dvd player- it's sensor has to be adjusted so that its power increases. on youtube, i saw some people increasing it's power using a potentiometer, is the same possible here? i have taken the cd player apart and cleaned the laser, but to no avail. it takes a lot of time to load and play a disk. There are no spare parts available for the DVD player since its over 20 years old
完成的
@arnavmalhotra
Usually an IC doesn't fail in just one area of its function so check where the switches connect to because it must be something common to all.
Also adjusting lasers can be difficult without the right equipment.
Have you tried using the part numbers when searching for parts?
完成的
Yes, I have tried searching for parts both with Google lens and via part no.s I just get hinresults found. What are the 'right tools' for adjusting the laser?
完成的
@arnavmalhotra
You would need an oscilloscope to start with.
Although given how old the player is no doubt the laser diode is on its last legs anyway.
See p.29 of the manual.
完成的
Yeah probably. Let's leave the disk, because I don't think it can be fixed. My main concern would be the buttons not working. Do you think those resistors could have failed? Unfortunately I don't have a multimeter to check that, so is there any other way?
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Arnav Malhotra 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 27
总计 312
