跳转到主内容
加入维修社区 - 创建账户
Part of the Lenovo G Series of everyday laptops released in November 2012.
How to check lenovo laptop battery ic
I replaced defective cells with brand new.. I am getting 10v @ positive & negative terminal of ic but my laptop is not starting at all
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @sumeetbadyal
What is the complete model number of the laptop as shown on the information label on the bottom of the laptop?
Does the laptop start with the charger connected?
10V doesn't seem enough voltage as most batteries are 12V when fully charged
完成的
Model number is lenovo g580.
Yes it does.
On the label of battery it is 10.8v /4100 mah written..... Which I am getting at input terminals of bms...
But i am not getting any output from output terminals of bms
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @sumeetbadyal
Here's a download link to the schematics for the two different motherboard models that may be used in your laptop.
Click on the appropriate link for your motherboard
You may have to trace the circuit back from the battery terminals to see where they go to.
Have you tried uninstalling/reinstalling the Microsoft ACPI-Compliant Control Method battery drivers in Device Manager?
这个答案有帮助吗?
得分 1
2条评论:
I have different problem sir.
On multimeter i am not getting output voltage from bms... That to from + ve terminal..
完成的
@sumeetbadyal
One of the schematics above should be applicable to your motherboard.
If you're not getting power out from the BMS verify that power is getting into the BMS on the correct terminal to actuate the BMS and not just that it is power being fed through the BMS.
You will need to know how to read schematics to work it out.
完成的
添加一条评论
Check the Lenovo laptop battery IC by measuring voltage at key SMBus (SCL/SDA) pins and ensuring proper communication with the motherboard, as just 10V at terminals doesn't confirm IC functionality
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sumeet Badyal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 237
