跳转到主内容
iPhone 13 mini 于 2021 年 9 月 24 日发布,它是 Apple iPhone 13 的缩小版,也是第二款的迷你 iPhone。 iPhone 13 mini 具有 5.4 英寸 OLED屏幕、A15 仿生处理器和后置双摄像头。
Unable to finish battery repair with Repair Assistant
I have managed to replace the battery in my iPhone 13 mini successfully. The phone seems to work fine but the "Finish repair & restart" item is not showing up in the Settings app. It showed at first but when I tried using it it failed (something about failing to contact the server). I retried a couple more times, but the item just disappeared (nor is it available in Settings > General > About > Parts & Service History, it shows that my battery is an "unknown part"). I tried restarting, making sure my phone is connected to WiFi, disabling PiHole, nothing helped.
I hear the repair assistant is still new and very flaky, but I was wondering if I can still finish the repair. Also, is there a point in contacting Apple support about this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Hi Andrii,
did you try this:
Phone is off
While holding down both the volume up and volume down buttons, plug the iPhone into a power adapter until the Apple logo appears
这个答案有帮助吗?
得分 0
1条评论:
Hi Michael! Thanks for the tip. I managed to boot my iPhone into Repair Assistant by following the steps you suggested, but when I tried to finish the repair I got an error message: "Unable to Configure Battery. This part could not be configured because it is not a genuine Apple part or may not be functioning correctly. Check that the part is properly connected and try again. For more information, refer to the iPhone service manual for this device. You can continue using your iPhone, but may experience unexpected behavior. View all of your repair details in the Parts & Service History in Settings."
完成的
添加一条评论
添加你的答案
Andrii 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 95
