跳转到主内容
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
PS4 still has stick drift after joystick module replacement
Help! I have changed both the joystick modules on my ps4 controller, I got the modules from eBay. It all works but it appears that the drift is still there which is completely bizarre.
I did find a calibration tool online that I thought had worked but when you unplug and plug the controller back in and check gamepad tester the drift is still there, I’m not certain the drift is exactly the same as it was before with the old joysticks but I’ve got my suspicions that it is.
Help please, it took me ages to change these modules and I just want it to be fixed so I can fix up some more 😀
Thanks!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Luke!
It's more likely that the new joysticks are broken too. But, it's also possible that a trace on the motherboard is damaged and causing this.
First, please inspect the motherboard to check if all the traces are OK (especially the traces near the joysticks, where you have soldered/desoldered).
If those are all OK (when in doubt, please share some pictures with us). Then buy some new Joysticks, and when you are there, why not buy the Hall Effect joysticks?? Those are great and take care for good with the drift (drift is no longer possible with the hall effect ones).
You can buy them here: https://www.aliexpress.us/item/325680714...
Please let us know how it goes!
这个答案有帮助吗?
得分 0
19条评论:
Thanks for the quick response! I will send you some pictures later on, I should have done that initially!
Luke
完成的
No problem at all! We will take a look once they are there :)! Thanks!
完成的
How do I add photos?
完成的
Okay I’ve added photos to the original post. Feel free to criticise my soldering, this was my first attempt, I think the one on the left was my first and the right my second 😀 thanks
完成的
Thanks! The left one (when the motherboard is facing is towards you) look like it's having small trace damages (back side). Is the left one having drift?? Please remove the left joystick and clean it with isopropyl alcohol. Then make again a picture of it (sorry). Can you share that one as well with us? Removing them both is fine as well, so we can check the other one too. After checking this, I can tell if the traces need to be fixed. Thanks again!
完成的
显示更多的14条评论
添加一条评论
A pack of ten hall sensor modules on eBay are cheap enough. I’ve done two controllers so far and they work well. Two more controllers to do then four working controllers again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LukeResells 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 77
总计 882
