跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
Where is the Wifi antenna located?
So I need to replace my wifi/bluetooth antenna. I have looked everywhere trying to figure this out. I know the 4s has two antennas
Upper
http://www.sw-box.com/iPhone-4S-WiFi-Ant...
Lower
[关联产品丢失或禁用: IF115-012]
I have seen both being referenced as the Wifi antenna in many places.
So which one is the actual Wifi antenna? if neither where is the wifi antenna?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I broke my wifi antenna cable when replacing front glass... does anybody have a good link for replacing the wifi antenna unit? Thanks!
完成的
添加一条评论
4个答案
最有帮助的答案
There is no actual wifi antenna.
BUT: as is with the iPhone 4 the big metal shield covering the flex connectors of the display and buttons etc is acting as the WIFI antenna.
If you have no WIFI signal you best check if the metal shield is correctly in place and that all screws are in place. If 1 screw is missing it could cause loss of WIFI as some screws are acting as signal path.
Also make sure that all metal surfaces of this metal shield are clean from anything (i.e. some dirt/oil from handling with hands). To be sure just clean it with alcohol/ipa.
这个答案有帮助吗?
得分 3
添加一条评论
"No antenna for wifi". This is true for iPhone 4, but iPhone 4S does use a separate wifi antenna, not the top bezel. Top screw simply holds the logic board onto the bezel to ensure cellular and GPS signal goes through. so I conclude Gido's answer not helping
The iPhone 4S has a wifi antenna around the headphone jack, it is easy to replace. Open up the device, look for 2 screws beside the headphone jack, one holds the antenna connector bracket, one grounds the antenna, remove them, disconnect the connector and peel the antenna off.
Ifixit has a way too over-disassembled guide calls it "upper antenna". That's the wifi antenna. You can use the guide for reference but don't follow the guide to remove everything
这个答案有帮助吗?
得分 2
添加一条评论
i believe it is the top ribbon cable and connector, in my experience, the emi shield acts as an antenna too, the signal wasnt as strong without the shield
这个答案有帮助吗?
得分 0
添加一条评论
Holy moly!!! Never has ANY advice in these forums worked, ever, but I am sending this post via wifi. I squeezed the metal around the side, then top, of my 4S and wifi picked up & connected for I even checked the settings. Annoying but good fix. Ty Ty ty
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 35,484
