跳转到主内容
Released 2010 RAM: 4 GB Hard Drive: 500 GB Processor: Intel Core 6th generation i7-6300 @ 2.80 GHz GPU: Intel Q43/Q45 Express Chipset Graphics
Why is my desktop beeping twice and won't display
my desktop beeps twice and won't turn on or display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There are LED light flashing codes and beeping codes to help you:
In your case are any lights flashing? For example:
  • Red Power LED flashes two times, once every second, followed by a two second pause.
  • Beeps 2 times and repeats stopping after the fifth iteration but LEDs continue until problem is solved.
Possible Causes:
Processor thermal protection activated:
  • A fan may be blocked by dust (very common cause) or not spinning.
  • The heatsink/fan assembly is not properly attached to the processor.
Things to do:
1. Ensure that the computer air vents are not blocked and the processor cooling fan is spinning.
2. Open hood, press power button, and see if the processor fan spins. If the processor fan is not spinning, make sure the fan's cable is plugged onto the system board header.
3. If fan is plugged in, but is not spinning, then replace fan.
这个答案有帮助吗?
得分 1
添加一条评论
Đã bao lâu rồi bạn ko vệ sinh máy, trường hợp này trước tiên bạn hãy tháo ram ra và làm sạch, và có thể phải pin cmos nếu đã nhiều năm rồi bạn chưa thay. Thân
TRanslation Vietnamese - English
How long has it been since you cleaned your computer? In this case, first remove the RAM and clean it, and maybe the cmos battery if you haven't changed it for many years. Best regards.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chuks williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 122
