跳转到主内容
加入维修社区 - 创建账户
发布于9月16日,苹果公司的 "小型 "旗舰智能手机,其拥有6.1英寸ProMotion OLED,三镜头后置摄像头系统,5G,以及围绕前置摄像头和顶部传感器新设计的 "灵动岛"。iPhone 13 Pro的继承者。
keep rebooting every 3 to 5 minutes
My iphone 14 pro keep rebooting every 3 to 5 minutes and the battery and screen was replaced but it keeps rebooting and panic said something about 0x80000 and i dont know what it means
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@earlmoney, you're looking at needing a new front sensor assembly, at least that's where the error code is indicating the problem is coming from. There's a wiki page on the SMC Panic Assertion Failed errors that details all the error codes we know of and what our best information indicates they mean.
iPhone SMC Panic Assertion Failed - iFixit
Here's the specific part your error is referring to.
iPhone 14 Pro Front Sensor Cable
Unfortunately, it's part of the Face ID system, so replacing it will mean Face ID will no longer work. I'd suggest checking the front sensor connector carefully for any bent pins or loose connection, but outside of that, any damage to that component means bye bye to Face ID.
iFixit doesn't have a guide specifically made for replacing the front sensor assembly, but the screen replacement guide gives you everything you need to know; the only difference is which part is new; the screen or the sensors.
iPhone 14 Pro Screen Replacement - iFixit Repair Guide
The only way I am aware of to get that part replaced and keep your Face id working is to pay Apple to replace the screen; their new ones come with the front sensors already attached so you'd be getting a new assembly with the new screen, which will fix the boot loop problem you're seeing. The only other alternative is to use their self repair program, which will save you a little money but you still have to buy the screen from Apple and use their tools to get access to the "calibration tool" that will pair the assembly to your phone.
Things may change with iOS 18 but I'm not clear on exactly how the changes will work for what you want to do; we will find out more as time goes on.
Replace the front sensor cable for an iPhone 14 Pro model A2650, A2889, A2890, A2892, or A2891. Fix problems with sensor functions.图片
产品
$28.99
这个答案有帮助吗?
得分 1
添加一条评论
It is the proximity sensor on the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
earl money 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 324
