跳转到主内容
Distributed by Verizon, the Ellipsis 7 is an Android 4.4 KitKat tablet that features a 7" display and a quad-core 1.2 GHz processor. Can also be identified with the model number QMV78.
Screen & back is pulling apart how to fix
My tablet is pulling apart from the front & back seems like the glue isn't holding I tried clipping back together by spring clips did not help stick it together. Please help with suggestions or where to get it fixed or if it's worth $$ to fix it?
Thank you db
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Looking at the Verizon Ellipsis 7 Battery Replacement guide, you can see that it is held together by latches rather than glue.
It pulling apart is most likely not due to glue failing in this case, but due to a bloating battery. You could take the back cover off and check the state of the battery, then look for a replacement and decide whether it's worth the cost.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ifixdb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 88
