How do I bypass Google login after wiping it?
you could try using this software, https://samfw.com/blog/samfw-frp-tool-1-...
这个答案有帮助吗?
Sam FW is a Definitely a good program I use it myself sometimes unfortunately for S24+ it doesn’t work Because of the security patch On the phone is too new Sam FW works up till 2022 security patches only
@edroid they could always try imeigurus, i have used them before. https://www.imeigurus.com/products/samsu...
@daniel… I’ve never tried them before but its a good option. I have and use Griffin-Unlocker software, they have many different phones in their database and newest update includes Samsung S24+ (BIT_3) newest security patch but it’s a subscription service so if you’re willing to pay $100 for it it’s worth it but your option is much cheaper! However I use it because of The variety of phone manufacturers & the many devices that pass through my hands that need unlocking!
@edroid does it work for all region phones
@tech_ni unfortunately I don’t believe so I only see two model numbers in the list SM-S926U SM-S926W But sometimes what’s compatible for one model works on other models as well if the hardware properties are similar… and they have different ways and tabs in the program for different ways of bypassing things like test points etc. KG removal all sorts of stuff it’s great program
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 29
总计 343
3条评论
I’m going to assume that it’s not your phone because you should know the google credentials to unlock the factory reset protection which only happens if you do a hard reset from the recovery menu.
由 Eric 完成的
You could try flashing new firmware onto the device. I'm not familiar with how this works on Samsung, as I am only really familiar with doing so with Blackview brand phones.
With a quick google search I managed to find: https://www.sammobile.com/samsung/galaxy...
I cannot talk of the risks involved as I am not familiar with this platform.
由 DegenFixer 完成的
Flashing new firmware won’t work Black view is different it uses a different chipset and the FRP partition is stored differently on those factory reset protection will still be there after reinstalling the firmware
由 Eric 完成的
