跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解信息和故障排除信息,它是 DualShock 系列的继任者。可通过产品型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
Orange light rapidly blinking non stop after fully charged
I can't identify what is causing this. I already tested in my PC with a software to check all buttons in my dualsense while plugged in and it works perfectly fine, but once I disconnect and try wireless connection, it shuts down, also when the controller is off, the battery is fully charged and it is plugged in, instead of just stop charging, it keeps flashing rapidly(not pulsating) the orange light. There is no issue with the battery, the only thing that was happening was stick drift and I sprayed some isopropyl alcohol into the stick. Does anyone had the same issue? Oh and the reset button doesn't seem to work either
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hi Rafael!
It's either the battery or something on the motherboard which shorted.
I would try to replace the battery first anyway, just to be like 100% sure.
If that didn't worked, then check the motherboard to see if it still looks OK.
Did you disassembled the device first before you used isopropyl alcohol? If not, then most likely something on the motherboard did short. As the battery was still connected.
这个答案有帮助吗?
得分 0
添加一条评论
Completing the @dan0 esponse, the ribbon cables can be a reason, they are so much sensitive and breaks very easy, ocasionally making a short.
To validate this case, remove the ribbon cables connected in the motherboard, connect your battery and after, connect the board with the usb in computer, this should turn on the controller (with usb connection the controller is always on) in case these cables are the problem.
这个答案有帮助吗?
得分 0
添加一条评论
Hello. Was you able to find the reason of problem? After changing analog sticks to new with Hall effect I have same behavior. Probably I messed up somewhere during soldering. Now I don't know how to fix it.
这个答案有帮助吗?
得分 0
1条评论:
Post a photo of the motherboar here, so anyone can help you better.
Clean all the motherboard whit alcohol, this can help if you dont see any visible short
由完成的
添加一条评论
添加你的答案
Rafael 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 68
总计 890
