跳转到主内容
Why does it make some commands which I didn't input?
The device sometimes acts as if there is someone other than me who is controlling it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
On rare occasions it's possible for a misbehaving or malevolent app to cause this kind of behavior, but in most cases it turns out to be a phenomenon called ghost touch. It's caused by damage to the digitizer that results in electrical noise on the signal lines being interpreted as touch inputs.
You will definitely want to eliminate software as a possibility; start with restarting the phone, doing a hard reset, booting into safe mode and as a last resort restoring the phone to factory settings. If it is still having issues after all that, then the problem is almost certainly in the digitizer.
Since the digitizer is bonded to the display, the fix for a bad digitizer is to replace the screen. iFixit doesn't have a guide for your particular phone, but the Spanish site Nadie Me Llama Gallina has just what you need.
Manuales / Honor 8X / screen - Nadie Me Llama Gallina
The screen itself seems to be readily available and since this is an older phone using LCD technology, the replacements are pretty inexpensive. I'd suggest starting out with sites like Amazon, eBay and AliExpress, but there will be many other choices to be found on a general internet search.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dexogan Seven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 96
