跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad 3 15IIL05 是一款定位中端的笔记本电脑,专为常规计算任务设计。
Powers on but no display output
The screen on my Lenovo ideapad 3 often glitches out then causes the computer to freeze, notably this only seems to happen when the computer is under some sought of physical strain. after it freezes I have to power it off then often when I try to power it back on again the power light goes on, the fans spool up but there is no output to the display, when I try an external display, nothing. Thanks for any help
Actualización (09/16/24)
@oldturkey03 I opened it up but i can't really tell, but I took a photo so can you see anything? https://imgur.com/a/BUYaowN
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@rowangadhia this "I try an external display, nothing" in combination with this "this only seems to happen when the computer is under some sought of physical strain." it does sound like you are having an issue with the GPU or possibly even the CPU since it does freeze. Time to open it up and to check the motherboard. You also want to check, and possibly change the thermal paste, as well as clean all the air inlets etc. Just in case this is an issue with overheating. Also, try a different RAM module, make sure that yours is properly seated etc.
Use this Ideapad 3 15IIL05 Hardware Maintenance Manual to work on your Lenovo. Page 36 and on are about the fan and the heatsink. Use something like Lenovo Thinkpad X1 Carbon (4th Gen) 导热硅脂更换 for a repaste (different model, same idea).
这个答案有帮助吗?
得分 0
8条评论:
is there any chance there is a loose cable or connector? I really hope it isn't a problem with the chipset!
由完成的
@rowangadhia sure. That is always a possibility. Just remember, a loose cable would have this error no matter what. It would not depend on the "workload" Also, with a loose cable an external monitor would still work since the connector for that is soldered to the motherboard. There is nothing wrong with checking everything out.
由完成的
@oldturkey03 when i mean workload, I mean when i lift it up or move it, so I think it could be something is shifting when I lift it up.
由完成的
@rowangadhia Ah, I see. I mistook it as workload on the processor. Sure, use the maintenance manual and open it up. Take a look and let us know what you find.
由完成的
@rowangadhia the board looks okay, but that only means I can't see any obvious damaged components. I can't make out the board number (beside the Fan) Looks like an NM-0031 Can you verify this number?
由完成的
显示更多的3条评论
添加一条评论
添加你的答案
Travelling Nomad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 68
总计 1,397
