humidifier and iMac, monitor is acting weird
hi, as of last week I had my humidifier on in the same room where my imac is located. now I've noticed that the images are not as clear as before. Could it because of the humidifier?
It sounds like the humidifier might be causing the problem. When I took my MacBook Pro out in the sun when it was very humid I got a "hazy" affect on the screen and things weren't very clear as you describe them to be. What I figured out was that the haze was coming from a thin layer of condensation between the glass and the LCD panel. I believe that because the humidifier is close to the iMac that it is causing a layer of condensation to form. I would try and take the humidifier out of the room to see if it got rid of the haze.
Hope this helps.
这个答案有帮助吗?
Thank you!!! Humidifier is out of the room!!! Thank you!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 765
