跳转到主内容
加入维修社区 - 创建账户
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
Why is my ps vita not charging and not turning on (battery is ok)
Ok so I have very strange problem, my ps vita slim isn't turning on and isn't charging light indicator isn't even flashing I watched some videos on youtube and searched on google, ifixit and on other forums and I can't find solution i think the port is working just fine. as I said in title the battery is ok battery voltage is 3,91v. I've tried other batteries , charging it with phone charger , home button + r button + power button combination. and it still not working pls help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
Probably something on the motherboard! Please take it apart and clean the motherboard. Also check the fuses on the board and the caps. If needed, replace them! You can also replace the motherboard for a new one.
If the battery is OK, then it must be motherboard related, I'm afraid...
这个答案有帮助吗?
得分 1
2条评论:
at this moment it is only charging battery (oragnge light works) but still ps vita isn't turning on :(
完成的
Yeah, most likely a fuse or cap that died. Please check those! Battery is fine as long as it charge (should be).
完成的
添加一条评论
添加你的答案
Smerfikz8 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 384
