跳转到主内容
Mobile network or, Sim signal isn't available
My new phone network isn't working properly.
My phone is working with handle stick means by WI-FI only
Huge issue in this phone. Company is big " Thags of Hindustan ".
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi there,
Here are a few troubleshooting steps you can try:
  1. Check SIM Card: Ensure that the SIM card is properly inserted into the phone. If it’s loose or not seated correctly, it might not connect to the network.
  2. Restart Your Phone: Sometimes a simple restart can resolve connectivity issues. Turn off your phone, wait a few seconds, and then turn it back on.
  3. Network Settings: Go to your phone’s network settings and make sure that it is set to automatically select the network. You can usually find this under Settings > Network & Internet > Mobile Network.
  4. Airplane Mode: Toggle Airplane Mode on and then off. This can help reset the network connections.
  5. Carrier Settings Update: Check if there are any updates for your carrier settings. These updates can sometimes resolve network issues.
  6. SIM Card Replacement: If possible, try using a different SIM card in your phone to see if the issue persists. This can help determine if the problem is with the SIM card or the phone itself.
  7. Network Coverage: Ensure that you are in an area with good network coverage. Sometimes weak signals can cause connectivity issues.
  8. Contact Your Carrier: Since you mentioned that the company is "Thags of Hindustan," it might be helpful to contact their customer support for assistance. They can check if there are any issues with your account or network in your area.
If you’ve tried these steps and the issue persists, there might be a hardware problem with the phone, or it could be a more specific issue related to your carrier. In that case, reaching out to the phone manufacturer’s support or visiting a service center might be necessary.
I hope this helps resolve the issue!
这个答案有帮助吗?
得分 1
1条评论:
If the need of hardware problem than I shall to want issue resolve.
Please suggest me for best and responsible Service centre.
reply must.
完成的
添加一条评论
Well do the following to fix the issue which you are facing:
  1. Restart Your Phone. .
  2. Check If you phone is on Airplane Mode.
  3. Reinsert SIM Card in the sim slot.
  4. Select Network Operator Manually.
  5. Toggle Airplane Mode On and Off.
  6. Check Network Coverage in your area.
  7. Update Phone Software.
  8. Reset you phones Network Settings.
这个答案有帮助吗?
得分 0
1条评论:
I have been followed all over rules, ways and instruction with motorola and you..
But not any improvement in this phone..
My phone is returned from motorola service centre Delhi.. service centre say that mother board issue in your phone. Wherein IMEI is not getting after search.Therefore I'm watched your video on YouTube and awake and awareness for hope to phone solutions.
Please help
I'm tried and tired 😫
完成的
添加一条评论
添加你的答案
Rangnathpandey 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 63
总计 505
