跳转到主内容
加入维修社区 - 创建账户
An Android smartphone made by vivo.
How to repair Battery swelling
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi,
Firstly you’ll need to order a new battery.
While you’re waiting for the battery to arrive, you can do a web search for “Vivo s1 battery replacement” and familiarise yourself with the process, so you are ready to do the job when you have the parts.
There currently is no Vivo battery replacement guide on iFixit, but you could create one while you’re doing the replacement, to help others out.
Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
Just to elaborate on Harry's response, the simple answer is that you can't fix a swelling battery; your only option is to replace it.
The swelling is caused by gasses building up inside the sealed plastic layer, and those gasses are caused by the chemical reactions inside the battery breaking down and no longer working correctly. So the very act of swelling right there tells you the battery is failing, and the swelling can easily cause problems like dislodging the screen or back of the phone. If it goes on too long, eventually it's possible for the battery to catch fire (remember the Galaxy Note 7?), so you really do want to replace that battery ASAP.
这个答案有帮助吗?
得分 1
添加一条评论
I'm a certified DELL server/pc tech. They are correct. Has to be replaced. Can't be repaired.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Akatsuki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 118
