跳转到主内容
9 月 24 日发布的苹果 2021 旗舰智能手机配备 6.1 英寸 ProMotion OLED 显示屏、全新三镜头后置摄像头系统和 5G。iPhone 13 Pro 是 iPhone 12 Pro 的继任者。
Back panel glass replacement problem due to camera bezel (telephoto)
Hello everybody,
i'am new here and this is my first post.
I am replacing the rear glasss of iphone 13 pro and i have problem with the new glass and the camera bezel (or whatever it is). That aluminum ring around the camera, ultra wide one is tight, normal lens is also ok, but the one on telephoto lens is moving freely. And i have the glass panel with large holes for lenses.
Is there something wrong, was it badly repaired before or i'm just missing something? Hope photos will show what i mean.
Thank you if you could help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Finally kinda found by myself with help of somebody. hat thing is kinda disturbing, the glass backpanel that comes from the factory goes underneath of each of this aluminium rings. When you break the glass, two lenses (but telephoto) are made with an inner ring made of aluminium also, and they are not mofing so freely. But telephoto lens do not have same logic.
I do not know if this phone was already repaired before, but if it comes from the factory like this, i can see absolutely no logic in there. So i just put some glue underneath that aluminium ring, and glued the new back glass.
The thing is, that replacement backglass, have larger holes for lenses (not like the factory one that goes underneath the aluminium cache). And then you are new to these repairs, you cannot understand it, and you're stumbled.
Hope this will help somebody
这个答案有帮助吗?
得分 1
添加一条评论
Iphon 13 back panel change
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 104
总计 1,063
