跳转到主内容
加入维修社区 - 创建账户
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Display worked for 2 hours after Speaker repair and then gave up
I Just replaced both speakers on my MBP. It worked great at first, I was able to use my MBP for about 2h before it froze.
Now I can only hear the start up chime, but the backlight and display is not turning on at all.
I've checked all the cables and connecters that were reconnected during the repair. The internal display cables don't seem damaged (+ the display worked for 2h after the repair).
Tried to connect an external monitor via HDMI port which didn't work either.
What could be the culprit? Or maybe totally independent defect that didn't have anything to do with my repair? Weird coincidence then...
Update: I must have shorted out my logic board somehow. Ordered a replacement logic board and everything is working fine now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
13条评论:
You say you replaced the speakers what was the issue with them? Probably unrelated but interesting to know. In terms of what caused them to fail originally could potentially be causing the screen to fail now.
完成的
The left speaker was defective. It sounded all distorted and crackly. It actually wasn't the first time I did the repair. Replaced the speakers about 5 years ago for the first time.
完成的
My initial thought is you bent a display ribbon too far . Then you say it’s not displaying via HDMI. I’m thinking a board issue. I could be well wrong just a hunch. Hopefully someone more knowledgeable on Macs and iOS steps in .
完成的
When you replaced the speakers, did you have to remove the logic board? I just replaced a crackly right speaker in a 15" 2012 MBP, and found a way to do it without having to remove the board. But if you removed the board to replace the speaker, and if the video connector cable looks fine, my concern is that the logic board was damaged during replacement. You may not be able to fix this without replacing the board. One thing I might try would be to disconnect the internal display, and re-test the HDMI video. Another thing to look at is heat, since your MBP worked for a few hours before failing. There's even a 1% chance your Mac was about to fail anyway, and that replacing the speaker was unrelated.
完成的
Yes I had to remove the logic board. Not sure how to do it without removing it, because one of the screws of each speaker is right under it. I'm going to try your suggestion with disconnecting the internal display.
完成的
显示更多的8条评论
添加一条评论
1个答案
It’s probably repairable, but it will take someone with good MacBook Pro repair skills. Where about do you live country and nearest major city, maybe we can aim you to someone.
这个答案有帮助吗?
得分 0
1条评论:
I'm from a major city in Switzerland. But I don't think it's worth a professional repair anymore. It's been my back up for a while now.
完成的
添加一条评论
添加你的答案
Phix it Pham 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 32
总计 289
