跳转到主内容
加入维修社区 - 创建账户
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Why does my Wii U freeze when I try to open a game?
My wii u freezes when trying to open anything. I tried replacing the bluetooth module and then later I tried replacing the wifi module, as another guide said was the issue and that didn't solve the problem, except the problem got worse. Before replacing the wifi module, the wii u would freeze on the splash screen when loading a game, but then after I replaced it, the whole thing would freeze as soon as i clicked on something to open and not even get to the splash screen. Is there any advice on how I can fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
First, is the Wii U up to date? Is it modded? It does sound like something is failing in the NAND and thus the EMMC need to be replaced.
https://guide-images.cdn.ifixit.com/igi/... > Step 14 in the first picture you can see the Hynix chip on the top right.
That one probably need an replacement. Only things is, that it's hard to find this one and you need to de-solder it out with special soldering equipment and need experience with this.
You can also replace the motherboard, but this will be expensive, but way easier instead of fixing the EMMC. When replacing the motherboard, remember to change the disc drive it's PCB as well! It's married with your motherboard.
这个答案有帮助吗?
得分 1
2条评论:
No, it's not modded and not up to date because it always asks if I want to update. It can't update though because it freezes when trying to. (I actually tried booting it up again because I wanted to mod it)
完成的
Ah, yes this definitely sound like an issue with the NAND. You need to fix this :(.
完成的
添加一条评论
添加你的答案
NinjaDog251 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 34
总计 638
