跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for HP 15 Laptop PCs, specifically 15-dy models. The HP 15-dy is a budget laptop series featuring 15.6-inch touchscreen displays, Intel processors, DDR4 memory, and solid-state storage. Identified by model numbers starting with 15-dy.
What can I upgrade on my laptop?
I bought my laptop at Walmart recently and I want to give it a boost. I use it for working at home and a little bit of Minecrafting with my son. I am worried that the Minecraft game will bog it down over time and I don't want to do that nor do I want to buy a whole other laptop.
Here are the specs from Walmart:
  • HP 15.6" Laptop with micro-edge Full HD anti-glare display
  • Windows 11 Home, 12th Generation Intel Core i5-1235U Processor, Intel Iris Xe Graphics
  • 8 GB DDR4 RAM, 256 GB PCIe NVMe M.2 solid-state drive
  • Up to 10 hours video playback battery, Wi-Fi 5 and Bluetooth 5 wireless card
  • HP True Vision HD camera with AI noise removal, HP Fast Charge quick charging
What can be upgraded on it? Where do I buy the parts for it?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @kristinewright
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
完成的
@jayeff HP Laptop Model 15-dy5885wm
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @kristine4727
The laptop's memory, CPU and GPU specifications already equal or better the recommended system requirements¹ for the game.
¹Benchmarks comparing laptop CPU and GPU specifications versus system requirements for game
Intel i5-1235U vs Intel i7 6500u
Iris XE vs GTX940M GPU, Iris XE vs Radeon HD-8570D GPU
You could upgrade the memory as the laptop supports up to 32GB of DDR4 PC4-25600 3200MHz SODIMM ram over 2 ram slots i.e. 2 x 16GB modules as guaranteed by this supplier (not that you have to purchase from them).
If you decide to upgrade the ram, here's the maintenance and service guide taken from this support webpage for the laptop that will help. Go to p.31 to view the procedure to remove/replace the memory modules.
Performance wise there's nothing besides the memory that can be upgraded as the GPU is integrated with the CPU and it is hard mounted on the motherboard i.e. non removable.
Depending on your requirements you could increase the storage by replacing the 256GB NVME SSD with a larger capacity 2280 M.2 PCIe3x4 NVMe SSD e.g. 512GB or even 1TB (not sure if these require a heatsink but if they do there mightn't be enough space for it to be inserted)
I guess it may come down to how much you want to spend.
这个答案有帮助吗?
得分 1
7条评论:
Thank you! I will buy the RAM and bigger storage
完成的
@kristine4727
The ram link is OK as should be the ram, however the 1st link only shows "cart is empty" and no device
完成的
@jayeff https://www.amazon.com/gp/product/B08GJB...
There is the proper link. Will this one work for the SSD?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
K. Wright 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 58
总计 1,124
