@maxdmkzflwvgsva exact year and engine size? Leaking from where? Do you see stains on the floor after you drive it and park it? What have you checked? Since it is smoking white it could be burning it. Have you pulled the spark plugs and check the faces? Have you done a compression test to see if it has compression or possible has bad rings etc. As you can tell, there is not enough information available for us to give you a concrete answer. The more information you add, the better your chance of a helpful answer.
由 oldturkey03 完成的
