跳转到主内容
22" 16:10 LCD monitor introduced in 2007. This monitor may have noticeable color accuracy problems in some releases of Mac OS X without calibration.
My Monitor acer idk the module light green then close
The Monitor light green then close again then light green then close , the monitor doing it for 24 without stop I tried to change the power cable but the same thing happens PLS HELP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@shadow_xt2 could be a bad power board or a bad main board. You did not tell us if you have the monitor connected to a computer etc. We do need to know if you have anything that would display video. You can't just turn it on without being connected. If it is not connected, then this could be your backlight having failed.
Use the Acer AL2216W Service Guide and work through the troubleshooting section. After that, disassemble it and post some good pictures so we can see the boards etc. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ibrahim ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 92
