跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
Camera won't work after digitizer/lcd replacement
I replaced the digitizer/lcd and back panel with a new color mod. I have an issue with the antenna I believe. I think it is either weak or not working, cause I get no signal in my house. Yet to test it out outside, and yet to try the soldering trick to bypass the resistor I saw online.
Sorry, rant, main problem now:
Camera doesn't open. I have made sure to put the gold connector pin back on top of the logic board, under the screw, and it is hooked up properly. I suppose I need to try cleaning the connector still but I doubt that will fix it. I will try and post results. Any other ideas on how to fix camera? Aside from full camera replacement... I'm cheap :P
PS Rear camera
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I've looked very very closely all over the board and found NO missing capacitors. Nothing to solder. All the special clips of metal etc are all in their original and correct places.
I have cleaned all the contacts.
Also in question 1 I see it mention a little gold clip that seems detrimental to the functionality of the radio reception.
So I don't know if that is actually relevent on i4S or not.
But now I see no further steps I can take, and I still have no phone, and no camera. Wifi works mind you.
完成的
添加一条评论
1个答案
最有帮助的答案
Check out this link and skip to Question 2. The Solution is for an iPhone 4, however it is based off the same principles. Let me know how you go.
Martin
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex Vanderveen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,116
