跳转到主内容
加入维修社区 - 创建账户
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
Wii U Gamepad is Not Touch Screening.
I've been trying to find this issue but I keep seeing people almost having the same issue as me, but slightly different. My face buttons are all working fine (knock on wood) the ABXY and D pad all work fine. The issue is that the touch screen is not touch screening. I can't tap anything on it at all. I tried desyncing it from my system to resync it, but even then, I couldn't tap the symbols it showed on the TV because the touch screen was still not touching.
Is it a lost cause and I need to just bring it into a shop to be repaired or somethin'?? I'm worried getting the touch screen fixed will break the face buttons, as I've seen that happen commonly as well apparently.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
The touchscreen need an replacement. I repaired many of them and it’s easy to do it by yourself!
Guide: https://youtu.be/M3XtH1AP5Lo?si=uzfWyDxq...
Replacing it will solve it! Please check the video first, if you want to get it replaced for you, then bring it to a local repair shop.
Please let us know how it goes, and good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
darkrai dream 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 186
