型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
102 个问题 查看全部
Why does it not turn on?
Can i ask another question here? My friend gave me this same ipod model but when i used my iphone charger to charge it, it wont go thru. i meant to say it won't turn on. Do we turn it on the same thing we turn it off? I dont know about ipods.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
ernestuspenuela, first off, this is a great iPod, I have a couple of those and love the audio. Anyhow, the reason why it does not charge is because it requires a "Firewire" connection.This model really needs a firewire port to charge and restore and prefers to sync through firewire, even so sync through USBis supported. So, you will need a computer that either has a firewire port, or get an additional expansion card or the Apple Dock connector for this model. You will also need a Firewire AC adapter. Once you have this, your iPod should charge if the battery is still okay.
I know it sounds like a lot, but it really is not. You can get the chargers and the card at very reasonable prices. You can read about your iPod on here and amazingly enough, the user manual is still available right here. It is definitely a good investment. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
ernestuspenuela 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 689
