跳转到主内容
加入维修社区 - 创建账户
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
My tablets volume up and down button is not working .
my tablets volume up and down button is going inside my tablet when i pressess it . and its not working. if anyone knows how to repair it send a guid with video
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@yaminrashe84387 either the volume button has dislodged or your have a bad power button/volume flex cable. There are no specific guides for this task. I'd suggest that you start with something like this guide 三星Galaxy Tab 10.1吋主板更换 and step 7 shows you the flex needed. Here are the Disassembly & Reassembly from Samsung. The replacement flex is available at many online stores.
While you work on your tablet, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy! from Samsung
这个答案有帮助吗?
得分 0
添加一条评论
May be dust between switch or strip complaint. First u try to remove any dust over there with air . Otherwise ur tab needed dismantling and strip changing, if don't u have any idea about it don't try it find near by service shop. That's the better . For emergency case use safety pin or needles to press switch but this cause damage overthere
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yaminrasheed yamin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 350
