跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
home button doesn't work
i have just replace the back cove case and my home button doesn't work i don't know what to do ,please help i have an 3g iphone 16gb
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
This is a spot for Answers, not new Questions. For people to see this and help, start your own new Question.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Georgianem,
Replacing the back cover means that you completely disassembled the iPhone.
It seems that after re-assembling the iPhone, the connection between the Homebutton and the mainboard is interrupted.
The Homebutton, when you press it, usually gets in contact with the two (solder) joints that are located on the left side of the Dock-connector (in the manual for the iPhone 3G you see it in the picture of step 16 above "J3").
I would first check if the Dock connector sits correctly before I would try anything else.
Steffen
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
georgianemanuel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 381
