跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
How to replace the power IC, iPhone 3GS logic board?
So I posted awhile back about a 3gs I had got a hold of that did not seem to power on no matter what I do. I've already went through the standard trouble shooting. I've replaced the dock, and the battery. More recently another 3gs I got a hold of with a good logic board that works with the same combination of new parts that I've put together...
Now that being said its definitely the logic board. I also tried putting the bad logic board in another phone and it didn't work in there either. I'm having issues finding a good walk through for a power IC replacement or another means of troubleshooting that I can perform to diagnose what the issue is with the logic board itself. If anyone could point me in the right direction it would be much appreciated!
In addition I do have a multi-meter, but I can't seem to find any diagrams as to what I should be testing on the board or what kind of read outs I'm supposed to expect from it to determine whats working and whats not.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Cobaltthegreat start of with measuring the circuit as attached to this answer. The reason why you have a hard time finding instructions on replacing the power IC, is because it is not an easy thing to do. The only instructions I have seen (and definitely saved) are here. Again, hope you have some experience and good tools, as well as great eyesight :-) Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks sir! I have some soldering experience but that's about it. The broken logic board was a freebie so I figured it would be a good place to start tinkering. Nothing to lose! :) I'll let you know what I find out.
完成的
Sounds good, try to use hot air or IR soldering. Let us know how it is working out.
完成的
添加一条评论
添加你的答案
Cobaltthegreat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 9,767
