跳转到主内容
加入维修社区 - 创建账户
Model M5343 / 333 or 400 MHz G3 processor
Schematics for the PowerBook g3 lombard?
My powerbook g3 lombard won't turn on and I don't know why. The fan does not spin and the cpu doesn't get hot when I try to turn on the computer. I also tried replacing the 10v 100uf tantalum capacitors but it didn't make a difference. Not even the service manual helps.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
@maxplayz what numbers are printed on the logic board?
完成的
Do you mean the logic board part number?
完成的
@maxplayz anything like 661-2174 etc or a 820-____ number You did check to make sure that your power supply is still working etc.? You have checked the power/charging board for any damage? Which capacitor did you change and why? Post some good pictures of your boards with your Question. That way we can see what you see. 在已经存在的问题里加入图片
完成的
@oldturkey03 it's a fully working power supply and the capacitor I replaced was the 220uf 35v capacitor
完成的
@maxplayz how did you check that the power board is working? What voltages do you get on the board?
Post some pictures of your boards with your Question That way we can see what you see.
完成的
添加一条评论
1个答案
Post your request on BadCaps web site see if someone there can help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Playz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 49
总计 224
