跳转到主内容
修复你的物品
维修的权力
配件 & 工具
PlayStation accessory repair and support, mainly for controllers. Repair usually requires common screwdrivers and prying tools.
695 个问题 查看全部
PS3 Guitar Controller 2d button releasing on its own, can it be fixed?
My son's PS3 Guitar Hero Controller's second button on the fretboard is not acting quite right. He presses it and it may work, or if he's holding the note it may simply release itself even though he's still got it pressed. Sometimes it says it's pressed when another button is pressed. Is there something I can do to fix it or will he just need another controller?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
4个回答
已选择的解决方案
The trouble is that this isn't a frequent problem nor is it a frequent product, however:
You could try opening up the guitar and checking the soldering/wiring of the button to the board. Loose connections could cause the button to act varyingly and a lot of 'it works sometimes' problems are due to it.
这个答案有帮助吗?
得分 1
添加一条评论
Just something to note... When I opened my controller I noticed that the plastic rocker triggers 2 steel switches, one for the up stroke and one for a down stroke, the plastic on the rocker switch had worn down where it is in contact with each switch, to a point where they were no longer pressing the switches correctly.
swiftly repaired with some superglue and a split matchstick.
这个答案有帮助吗?
得分 0
添加一条评论
A good way to fix it is by taking the button off and blowing on the inside were the button i, because it could simply be that there is a lot of rubbish inside of it so it would be best to clean it out.
这个答案有帮助吗?
得分 0
添加一条评论
i need some info on how to fix my ps3 wired controller any ideas
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ELQ 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 2,212
