跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
How to diagnose scratchy sound issue? Don't think its headphone jack.
This 80G Classic is experiencing scratchy/poor sound issues. Tried several headphones, etc. but it's the iPod itself. Jiggling the headphone metal prong connector while inside the iPod does not produce a difference in sound as it would if the jack was not positioned correctly.
I opened the iPod and with headphones on to detect a sound difference, pressed on cables, the metal jack box, and all parts/cables connected to the jack assembly to see if something might be loose. Made no difference in sound. This leads me to think the headphone jack is not the problem, however I don't know what other part controls sound in order to troubleshoot.
Any ideas what to check?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Just to clarify, when music is playing the scratchy sound is there as well. When you stop the music, there is no static or scratchy noise. Audio is not clear in the background.
完成的
添加一条评论
2个答案
最有帮助的答案
Well, I still think it might be a bad headphone jack, but here's what you can try:
Try playing music through the docking port if you have like a music station or something. If the sound is scratchy then too, it's probably the motherboard that is bad. If it's not, it still might be a bad motherboard, but I'd lean toward guessing bad headphone jack. Just replace it, there's pretty cheap I think.
这个答案有帮助吗?
得分 1
添加一条评论
all ipods suck. apple knows they are defective but wont' do anything about it. they all have the same defect in manufacturing. people think it's the headphone jack but it's just poorly designed circuitry! i called apple and talked to an executive and they basically said "oh that's the old ipods and we stopped replacing them - the new ones are all fine" I say bullshit! F apple people stop buying their overpriced crap!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jody 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 8,187
